Terry Wighs
Date:  4-4-2006
Number of Hours:  0.00
Brief Description:  Shop layout
The dimensions of my shop are 16' X 20' . I have ample space if I plan ahead at each phase. The paint booth I used for internal primer painting has been disassembled after the tail kit was finished. I am currently building a large 7.6ft X 18.6ft paint booth. The ceiling of the booth is suspended and is alreadly installed, however you can't see it in the lower left picture, The walls simply assemble in place when needed, and disassemble when there is no painting activitiy. The air is brought into the booth with a 21"X21" fan and passes through a furnace filter, then exits out the other wall ot the booth through another furnace filter and to the outside. More on this later.
Primary work bench.
Primary work bench.
Secondary bench, ginder, drill press, vice on left out of veiw
Band saw, very useful.
