Brief Description: Drilled top and bottom cowling piano hinge
Measured and drilled two piano hinges for the left and right side piano hinge that holds the top and bottom cowling together. Installed the top hinge with rivets and epoxy on both sides. Fitted and partially drilled the bottom holes. Mounted the hinge plate for the oil filler access door with rivets and epoxy.
