Brief Description: Part 1 - Test Fit canopy and made wood plate for s
Measured for clearance and cut baffling that was causing the top cowling to rub. After the cowling layed flat on the firewall I made a 3/4" wood block for attaching the spinner plate to the prop extension hub.
Leveled the fuselage side to side and measured both cowling sides for an exact center fit.
