Brief Description: Ran wiring for Pitch trim servo and tail strobe
Ran wiring for the tail strobe and pitch servo. Extended wiring from the elevator servo and ran db9 style pins to make the connections. Calibrated and tested the servo from the VPX.
Also ran the tail strobe wiring and tested.The tail strobe seems to be defective. When I power it on it stays bright and does not flash and gets very hot. I may have to return this unit to Ztronics.
