Ran angle from the firewall to the intermediate bulkhead and installed platenuts for the Skyview Engine Module. All modules will be installed face down so that if I need to access or remove any module I will be able to unscrew from underneath the avionics panel.
Next steps will be to drill a hole through the firewall for the engine monitoring cables. I will have two holes through the firewall. One for the engine monitoring wiring and a second for the #6 main cable from the battery to the VP-X.
