Brief Description: 3 - Drilled Canopy Plexiglass to the Frame
Started with the top cabin frame and drilled the top four center holes using a 1/8" plexiglass bit. Used the cordless screwdriver and went slow with little pressure. Ran every other hole down both sides of the canopy roll bar and then every other side rail. Went back and drilled the remaining holes.
