Brief Description: Canopy frame Primed and Riveted
Deburred, countersunk, cleaned, primed and riveted the canopy frame. Bit the bullet and purchased another two gallons of AKZO two part epoxy primer. I decided to spend the money and use this as the primer vs. the rattle can. I think this primer works better with the top coat vs. the rattle can prime.
Next steps in the plan are to start fitting the Plexiglass.
