Brief Description: Part 2 - Tapping Canopy blocks and fabricating nut
Drilled and tapped the canopy strut blocks per plans. Read VAF and decided to make nutplates to hold the two screws rather than use two nuts. Getting your hands around and under the fuselage to install two nuts is very time consuming due to the restricted space. I opted to make the two nutplates out of .063 stock.
