Installed Van's ADHR mount which I am using for the Skyview transponder. Drilled, dimpled, deburred per plans. Installed plate nuts and installed the transponder mount. Primed and riveted top plate and clecoed for the remaining riveting.
Last step will be to rivet the side and bottom skin rivets.
