Brief Description: Dynon Roll Servo install Right Wing
Made the decision that I will be going with the Skyview Avionics package from Dynon over the past weekend. Ordered the Roll and Pitch servo and bracket assembly from Aircraft Spruce which arrived by UPS in the afternoon. Had some time in the evening so I installed the servo and brackets per plans. Very easy with good documentation and diagrams. There is one bolt that Dynon indicates can be used from the original configuration to the pushrod that does not have enough thread showing (the one without torque seal). I will change that out with the next size AN3 bolt.
Spent some time reviewing wiring and assocated fittings to extend the pitot heat, servo wires and landing lights to the wing root and then some. Put an order through which will queue up this weekends building tasks.
