Toms RV9-A project
Date:  11-7-2010
Brief Description:  Primed parts and Finished Aileron Pushrod
Cleaned the inside of the aileron pushrod by cutting up a scotchbrite strip and pushing it through the tube with some laquer thinner. I then shoved a paper towel through the tube to clean out the debris. Came out nice and clean after I shot some compressor air through the tube to dry it out. Mixed up Azko two part primer and primed the rudder stops and some other misc parts. I then took the remaining primer, taped up one end of the tubes and sloshed around for about 5 minutes. Drained and let dry.
Next step I drilled out the holes to final size using #30 bit and then measureed the rivets for length. The 12 size is a bit too long so I shaved about a 64th and measured with my gap tool. Setup my C frame rivet tool with a cup bit. Rivets came out pretty good. They stick out a bit but according to the rivet tool they are the correct head size.
Primed some parts and sloshed pushrod
left side closeup
left side closeup
right side closeup
right side closeup
