Toms RV9-A project
RV-9A
05- Fuselage
10-31-2010
Bottom Rudder Fairing test fit
Did a test cut and fit of the bottom rudder fairing. Needs some small adjustment. In the picture you can see a small gap in the trailing edge of the rudder. I also marked the vertical spacing for blind rivets, which will be done next time around.
bottom rudder fairing test cut
RV-9A Home
1246
01- Why RV-9
02- Shop
03- Empennage
04 - Wings
73
172
05- Fuselage
121
238
06 - Gear & Fairing
07 - Firewall Fwd
70
150
08 - FAB
09- Tip-Up Canopy
69
152
10 - Cowl & Baffle
11 - Avionics
79
173
12 - Registration
13 - Training
14 - Phase 1 Testing
15 - RV Trips
99 - Miscellaneous
41
