Toms RV9-A project
RV-9A
03- Empennage
7-17-2010
Elevator Horn Bolts
Drilled both elevator horn bolts to the center bearing. Locked wing in neutral position and drilled each bolt. Bolt was drilled using a bearing sleeve through the center bearing. Finished pictures below.
RV-9A Home
1246
01- Why RV-9
02- Shop
03- Empennage
04 - Wings
73
172
05- Fuselage
121
238
06 - Gear & Fairing
07 - Firewall Fwd
70
150
08 - FAB
09- Tip-Up Canopy
69
152
10 - Cowl & Baffle
11 - Avionics
79
173
12 - Registration
13 - Training
14 - Phase 1 Testing
15 - RV Trips
99 - Miscellaneous
41
