Brief Description: Elevator Balancing and wing part prep
Unbolted the vertical stabilizer and rudder in prep for finalizing some loose ends on the empennage. Reviewed plans for the wing and pulled parts for priming. Deburred all parts and sanded down (picture taken before sanding) for priming. Forgot to countersink the rudder stop so I did that and will also reprime the countersunk area. Also balanced the elevators and drilled out some lead on the passenger side. The pilot side was left alone as it balanced well without any lead removal due to the electric trim.
