Reinstall botls for fuel pump Finish cabin heat cable installation Install washers in elevator push pull tubes Fix Canopy front skin from rubbing on open / close Splice cut wire for OAT sensor Finish running NAX coax to avionics Fuel flow testing First Engine Start Install all fairings, inspection plates, cockpit interionr (all) Weight and balance
