Brief Description: Canopy Frame mechanical countersinking - Day 3
Took apart the Canopy Frame and started mechanically countersinking the forward facing holes. These will get standard rivets so they were countersunk 100 degrees. The aft facing holes need to be CS4-4 rivets since you cannot access the assembly for standard rivets. These rivets use 120 degree countersink bits which I have on order from cleveland supply.
