Matched drilled two pairs of rudder pedals, deburred and clecoed on frame for test fit. Temporarily hung brake cylinders for alignment for drilling the bottom hole for the bracket. All parts will be cleaned and primed then riveted before the entire rudder assembly is removed and stored for later reinstallation.
