Brief Description: Enlarging Ribs for Control Stick Fitting
Drilled out the pre-punched hole in the rib and scored a 1-1/2" diameter hole by hand with a hole saw. Used the Dremel metal cutting flute bit and followed the outline on the rib. Attached the control assembly temporarily and adjusted the hole to ensure clearance when the control stick is pushed fully forward. Hand filed and removed burs on the ribs
