Brief Description: Adjusted control stick clearance
Saw that the control stick needed some adjustment due to rubbing when pushing the stick forward. This was starting to make a cut in the control stick mechanism.The floor ribs started to cut through the powder coat so I sanded and reprimed the area. I also trimmed down the two center rib flanges so that there was sufficient clearance.
