Completed running the wiring for the Stick Grips. Final layout is as follows:
Coolie hat (Aileron trim and Elevator Trim) Trigger - PTT Com Index button - Auto Pilot Disconnect Left Button - GTN650 Primary / Secondary radio swap Right Button - Transponder Ident
Also installed platenuts and a 10 circuit terminal barrier strip for internconnecting the tail and strobe lights under the avionics panel.
