Brief Description: Drilled holes for Nose Weel fairing tow bar
Ordered a tow bar earlier in the week from ACS and drilled holes through the nosewheel fairing for the tow bar.
Installed the left and right brackets on the fairing while it was not on the fork. Got a piece of aluminum tube 3/4" and used as a hole locator by cutting the tube to the inside length of the fairing and then using a sharpie marking from the outside where the tube laid flush across both brackets. Drilled pilot hole then enlarged with a stepped drill bit.
For now I will remove the fairing until later in phase one flight testing.
