Tried first to use the vacuum pump to add brake fluid to the lines from the bottom up. Tried for 10 minutes to pump with no fluid being pulled up from the brake calipers. Decided to Order an Oiler from Amazon and tried pumping from below. That did not work either. Tried a combination of vacuum pumping and oiler pumping and that did the trick. Had enough brake fluid left to fill the 1 pint oiler for future fills. During the fill I noticed I reversed the right side right wheel cylinder and reversed the fittings. Brakes are very firm. Removed 1 inch of brake fluid from the top of the reservior and replaced the cap.
