Toms RV9-A project
Date:  4-7-2013
Number of Hours:  2.50
Brief Description:  Antenna Coax Runs
Ran Com1 and Com2 coax along both outboard sections of the fuselage from just aft of the wing root. Ran through the main spar and along the floor underneath the fuselage angles. Used 3/8" vinyl tubint as condut and secured with adel clamps.
Ran UAT antenna coax located in the tail section and connected to the Skyview ADSB unit on the left side fuselage behind the baggage compartment.
Ran a patch cable of TNC connectors for the Garmin GPS puck.
Ran TNC and BNC short stub connector for the Transponder blade antenna.
Adel clamps mount
Adel clamps mount
Com andenna mount just aft of the wing root outboard bay
runs under the angle to the front of the fuselage
