Brief Description: FAB Part 5 - Reinforced Fiberglass FAB air inlet
Removed the styrofoam mold and sanded down the outside of the plug and ran the dremel across the top to even out the plug. Added two layers of fiberglass cloth around the outside of the plug and then pored an epoxy / flox mix at the base of the plug for added strength. I will let this set for the day to cure and then do a final sanding inside and cut the top straight.
