Brief Description: Epoxy skim coat top cowling inside and out
Mixed up some thinned down epoxy with acetone and coated the inside and outside of the top cowling. The top cowling has significant pin holes and before the first coat dried I mexied up another coat and applied to the holes that were not filled. Thie top will require sanding and then topcoated with a primer.
