Toms RV9-A project
Date:  9-21-2012
Brief Description:  Part 1 - Test Fit canopy and made wood plate for s
Measured for clearance and cut baffling that was causing the top cowling to rub. After the cowling layed flat on the firewall I made a 3/4" wood block for attaching the spinner plate to the prop extension hub.
Leveled the fuselage side to side and measured both cowling sides for an exact center fit.
Drilled lower gear leg slot on the bottom canopy.
Cowling test fit on fuselage
side view
side view
bottom cowling slot for gear leg
