Brief Description: Install battery box and firewall recess
Riveted the firewall recess to the firewall per plans. Fabricated and installed battery box on firewall. Plans are straight forward in this area and easy to follow. Installed nutplates, countersunk angles and dimpled battery box per plans. Drilled out existing rivet holes on the firewall and bolted to the firewall.
Fabricated backing plate for battery contact master and starter solonoid.
