Brief Description: Right Wing Aileron pushrod clearance
Moved on to the Right wing for finishing up the remaining items. Riveted the Aileron stop and used the dremel small drum sander to enlarge the trailing bulkhead hole for clearance through the entire aileron travel. total sweep is55 degrees which matches the left wing travel. Unbolted the flap and clecoed the bottom skin to check for allignment. Next job will be to sand, dimple then rivet.
