Brief Description: Left Wingtip initial installation
Completed rivteing the remaining bottom wing skins. Cut out, drilled and clecoed the left wingtip fairing. Wingtip trailing edge lined up perfect with the alieron in the neutral position. I continue to be amazed at the precision of how the parts fit together and the CAD drawings are very accurate.
Left wingtip fairing clecoed
Still need to adjust the aileron spacing a bit
trailing edge lines up perfect with Aileron in neutral position
