Brief Description: Oil cooler shutter final installation
Ordered a new Oil cooler shutter from Vans as the first one was drilled incorrectly. Drilled holes, mounted with a washer as a spacer and intatlled the push pull wire with Adel clamps.
This is a tempory install as I will need to remove and pull through the firewall and decide exactly where to run the cable.See previous log entry on firewall pass through solution.
