Drilled rear mounting screws and dimled with Tinnerman washers. Did final cut and sanding on the lower intersection fairing. Installed plate nuts and screws. Still need to drill the two front screws. Had to order a flexible small light from Amazon as I cannot see the holes through by shining a light on the outside wheel pant. Looks like the wheel gets in the way. Will try snaking a tiny light and see if that can identify where I need to drill the hole.
Also made the tire gap 5/8" around the tire per pland, cut and sanded.
Moved on to other miscellaneous thisgs until I get it on Wednesday.
