Toms RV9-A project
RV-9A
Run Fuel Line right
Punched the Andair fuel valve per instructions to keep the hex screw from backing out. Started running the right side fuel line. Hand bent the offset 90 degree angles and ran outside to the fuselage.
punch locked andair fuel valve
Right Side fuel tubing
Right side run
RV-9A Home
1246
01- Why RV-9
02- Shop
03- Empennage
04 - Wings
73
172
05- Fuselage
121
238
06 - Gear & Fairing
07 - Firewall Fwd
70
150
08 - FAB
09- Tip-Up Canopy
69
152
10 - Cowl & Baffle
11 - Avionics
79
173
12 - Registration
13 - Training
14 - Phase 1 Testing
15 - RV Trips
99 - Miscellaneous
41
