Brief Description: Reworked Engine attachment and installed cotter pi
Had a lull in building for the past two weeks. Went Camping before the season ended in Lancaster and winterized and put the pop up for seasonal storage.
Spent some time cleaning up and reorganizing the garage. Reworked the bottom Lourd mount pairs. Forgot to install an additinal washer in the bottom mounts that was indicated in the drawing. Torqued and installed cotter pins for the Lourd mount bolts. Torqued and installe cotter pins to the engine frame mounting bolts.
Reviewed steps for installing the Vetterman Exhaust pipes. Ordered a 24 tpi band saw blade at Amazon to cut down the pipes per plans.
