Eds Vans RV-6A/7A Web Site
Date:  12-11-2009
Number of Hours:  0.00
Brief Description:  Build rotisserie firewall frame.
Before I put the bottom forward skin on I thought I would go ahead and build the firewall rotisserie frame. I’ve decided to use wood.
Started by clamping the verticall 2/4 pieces on.
Then clamping the horizontal 2/4 pieces on.
Attached temporary angles to keep all 4 2/4 sections stable.
Attach 4 corner 1/4" plywood gussets.
Drill and bolt from inside out the 6 1/4" attach holes.
Remove temporary angles.
Frame is complete and attached. Now for the center section that attaches to the engine stand.
Rotisserie frame attached.
