Brief Description: Drill Forward Ball Stud Mounts to Fuselage.
The final stage to installing the Canopy Lift Struts is to drill the Forward Ball Stud Mounts to the fuselage.
The mounts were drilled using a smaller #27 for drilling through the fuselage. After they were drilled through the fuselage I enlarged the holes in the fuselage to #12 and enlarged the holes in the Ball Stud Mounts to #21. Then tapped the Ball Stud Mounts to accept the 10-32 screws.
