Eds Vans RV-6A/7A Web Site
RV-7A
Finishing Kit
3-9-2013
Install Steps. Drill Step Anchor Block. 9
Used the drill press to drill the 3 #12 holes in the Step Anchor Blocks. Then drill the floor rib web through the Anchor Block. Not shown here is drilling through the anchor block through the step support tube. I drilled it if from each side.
Drill Step Anchor Plate.
Drill Anchor Plate to Floor Rib.
Aerolite 103 Home
RV-6A Home
RV-7A Home
Finishing Kit
134
Flap Actuator
Hole Fixing
Personel
Roll Bar
57
Seat Back
Shop
Wing Cradle
Wing Hardware
Wing Jig
