Eds Vans RV-6A/7A Web Site
Date:  2-13-2013
Number of Hours:  0.00
Brief Description:  Canopy latch Mechanism. Tap Push Rod. 2
Here's how I taped the ends of the canopy latch C-710 Push rod I found it difficult keeping the tap parallel with the rod while starting the tap. The tap does not go in easily. A good clamp on the rod is a must. So, I used my lathe. The chuck has good clamping force. The center rest thingy was used to keep the tap parallel with the rod. I turned the chuck by hand. Worked great.
Tapping the C-710 Push Rod
