Eds Vans RV-6A/7A Web Site
Date:  11-20-2012
Number of Hours:  0.00
Brief Description:  Decrease Diameter of WD-619 Release Shaft.
WD-619 Canopy Release Shaft was bigger then the hole in the C-620 Bearing Block.
So, I have a choice. Decrease the diameter of the steel shaft or increase the diameter of the nylon hole.
Decided to decrease the diameter of the steel shift of the WD-619.
I needed to spin it and file it down. Here you can see I put a bolt through the shaft and spun it on my lathe. A fine file did the trick.
Shaft will not fit in block.
Bolt through shaft to chuck it.
Spin and file it down slightly.
