After drilling the holes I tapped the center hole to accept the Ball Stud. The other 2 holes are drilled using a small #27 instead of the required larger #21. Why. You need to match drill the fuselage through these and I didn't want to screw up the holes due to drill bit wobble while match drilling. I'll enlarge them to #21 after drilling them to the fuselage.
