Brief Description: Drilling C-614 Split to Canopy Frame
You see in image 1 the larger #40 clecos through the Canopy Frame Splice Plate. I actually drilled smaller #40 first. Then once I was happy with the fit, went to the larger #30.
Then, the forward canopy frame web needs to be counter sunk. You see rivets in the holes. They are just there to test the depth of the counter sink.
While I'm at it, I'll drill the Canopy Frame fore/aft flat reinforcement bars through the skin.
