Brief Description: Rivet Rudder Pedal Center Support to Firewall.
I decided to go ahead and rivet on the rudder pedal center support to the firewall. I was going to buck these but found that my had squeezer could fit. The Pneumatic didn’t fit in the space. If I bucked I would of had to used the offset set.
After I riveted it on, I noticed that I needed 2 holes for the break lines to fit through.
