Brief Description: Decrease Diameter of WD-619 Release Shaft.
WD-619 Canopy Release Shaft was bigger then the hole in the C-620 Bearing Block. So, I have a choice. Decrease the diameter of the steel shaft or increase the diameter of the nylon hole. Decided to decrease the diameter of the steel shift of the WD-619. I needed to spin it and file it down. Here you can see I put a bolt through the shaft and spun it on my lathe. A fine file did the trick.
