Brief Description: 10. Match Drill Actuator Channel through F-766C.
Here is the start of actually fitting up the flap actuator. First thing to do is match drill the F-766C plate to the F-766A Flap Channel. Basically you draw a center line, drill an index hole in the plate then match drill the rest.
