Brief Description: F-726 Baggage Rib. Cut 1.5" hole for step.
The F-726 Baggage ribs have a tooling hole to center a 1.5” hole to accept the step. Be careful, the written plans calls for a 1 5/8” hole. The DWG is correct and the written plans are wrong I’m guessing because the diameter of the tube on the step is 1 ½”.
I adjusted the fly cutter and made a text hole in scrap. My holes are a couple of thousands larger then the tube.
