Eds Vans RV-6A/7A Web Site
Date:  4-4-2012
Number of Hours:  0.00
Brief Description:  Make fuselage rotisserie height adjustable.
Finally bit the bullet and make my rotisserie height adjustable. I also make an identical rotisserie stand for the tail end. Using a car jack I can raise or lower the height. Spins nice but is a bit bottom heavy. That will improve once I get some of the fuselage top parts mounted. Had to use care to assure the rotisserie ends mounted at right angles to the fuselage.
Rotisserie parts in the making.
Forward end fuselage  rotisserie.
Aft end fuselage rotisserie.
