Brief Description: Aileron - Joyce helps to mount ailerons.
Joyce helped me mount the second aileron. Joyce is my wifes sister. I went an extra mile on these ailerons by masking off the pulled rivets on the bottom spar and leading edge. I sanded them smooth with emery cloth and then scotch bright pad. Pulled rivets are bumpy and rough unless you do this.
Any way, the shop is all cleaned up and I get to start the flaps tomorrow.
