I Pro-Sealed - 1.) Inside and outside edge of the inspection plate flange. 2.) Inspection plate flange nutplates. 3.) Out board rib tooling hole. 4.) Fuel sender BNC connector. 5.) Flop tube rubber end. 6.) Out board sender plate wire connector. 7.) A few ribs that looked like they needed a bit more.
Next I'll install - 1.) Sender plates and wires. 2.) Vent and return line tubing. 3.) End ribs. 4.) Baffles. 5.) Z brakets. 6.) Inslection plate.
