Brief Description: Install leading edge/gas tank joint plate.
Here is the leading edge/gas tank joint plate. This was actually an effort. The rib here is undrilled and the actual joint plate is flat stock that needs to be bent to match the leading edge contour and then matched drilled through the leading edge skin. It's hard getting the joint plate jammed in there. Also it's hard lining up the rib edge to the skin edge because the joint plate is in the way. Before you drill through the skins to create the holes in the joint plate and rib you have to make sure it's lined up perfect. Here it is, all drilled, and I'm happy with it.
