Eds Vans RV-7A Web Site
Date:  8-28-2007
Number of Hours:  0.00
Brief Description:  All HS holes are drilled. Clecoed every other hole
Well, this HS looks almost done doesn't it.
Well, not really. All holes are drilled and a cleco in every other hole.
The skeleton parts need to be labeled -
Totally taken apart -
All holes debured -
All holes dimpled -
Put back together with clecoes -
Then riveted.
Mindy enjoys using the cleco tool.
Every other hole clecoed.
Mindy helped again today.
Center section showing 2 spar's.
