Here is the flap housing and tunnel parts all primed up. Lots of plate nuts to install. Drilled the safety wire hole in the flap actuator motor shaft.
I deviated from the planes and used universal rivets instead of flush on the tunnel cover. I use flush rivets if they are in the air slip stream of if another part needs to fit over the rivet heads.
